MT Shift Linkage Bushings - Has anyone replaced theirs?
General discussion area for the L30-chassis Altima
OwnerCS
I need to find a way to replace some manual transmission shift linkage bushings. I tried ordering them from the dealer and learned they were part of a linkage rod assembly that has been discontinued.
Has anyone made or found a source for new linkage bushings for the shift linkage joint in the picture below?
The picture is from a 4th gen Maxima but I understand Altima and Sentras from the same period use the same joint and bushings.
centralcoaster33
Car: 1997 Nissan 240SX #5
I think I see the part numbers you'd need at this website:
https://parts.nissanusa.com/nissanparts ... &siteid=14
Perhaps you need to try a couple of dealerships to verify that you can't get what you're looking for. There's also a few dealerships that seem to have better connections than others. For example, West Covina has a thing called The Nismo Shop and they were the only ones able to get me some Nismo S-Tune coilovers.
Return to “2nd Generation Altima Sedan (1998-2001)”
