mt question
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
falcon381
Car: 2008 Nissan Versa SL Hatch w/ 6MT
this is probably a dumb question but when driving do you have to push the clutch in to go into neutral? i noticed the other day that i could shift into neutral w/out pushing the clutch in. i have always used the clutch to go into neutral. that being said i kind of taught myself to drive stick.
CodeRed
Car: 2008 Nissan Versa S MT
you CAN just pull it back into neutral but it's probably not good for your synchros
blindsnyper
Car: 2007 versa
if your not forcing it, it should be fine. you can also shift without the clutch. ive only done it 2 or 3 times on my V, but i did it in my 4runner all the time.
AG
Most of the time its possible at about 1700-2000 rpm
xtwoonamatchx
Car: 2007 Nissan Versa S
you dont need the clutch to go into neutral, but dont try and force it... blind_snyper... how did you shift without the clutch, im too afraid to grind, i HATE that noise.
#1Tango
i woulnd't recommend it ive done it like twice, its just rev matching, the clutch is easier just stick w. that
blindsnyper
Car: 2007 versa
xtwoonamatchx wrote: blind_snyper... how did you shift without the clutch, im too afraid to grind, i HATE that noise.
if you really want to know look it up on youtube
CodeRed
Shifting without the clutch is really easy. As blind said...look at youtube.
Return to “Versa Technical Discussions”
