MT fluid question
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
Sure_Shot
Car: 2008 Versa SL Tech 6speed
So, I had to do some work on my 6 speed that resulted in the need to replace my MT fluid. Here's my question: I'm at about 2800 kms, can I replace it with synthetic fluid, or should I not (does it need more break-in)? Also, if anyone else has done this already and has any tips or descriptions of the process I would welcome those. Thanks!
reyes1212
Car: '07 Nissan Versa Super Black
I've been needing to do this.I want synth mt fluid to make the shifts that much smoother.Get it
Sure_Shot
I just wasn't sure if I needed more of a break in period before making the switch to synthetic. Is this an issue?
Sure_Shot
bump!
Bubs daddy
Car: 2007 Nissan Versa SL
ABS, CVT
No. You don't need a break in period for synth oil, either with engine motor oil or trans oil.
viet510racer
Car: 08 Nissan Versa SL
can u write a "how to" change the mt fluid. i would also like to change mine. and what type of fluid are u going to use? pictures would help too haha
4DRSS
I've been wanting to change mine too. I'm gonna do it sometime this month and will snap some pics along the way. First question is, how many quarts does the transmission take? It's not listed in the owners manual for some reason????
bennyal
Car: Versa
My dealer want over $120 to drain and fill the MT fluid. Out of their mind!I'll be looking forward for you pics. >31K miles.
4DRSS
bennyal wrote:My dealer want over $120 to drain and fill the MT fluid. Out of their mind!I'll be looking forward for you pics. >31K miles.
I got the stuff to do it today, plan on tackling it tomorrow. I have 21K on my V, and can tell the gearbox is getting "notchy", especially now that it's getting colder. I think some synthetic fluid will be just what the Dr. ordered.
4DRSS
Here's my writeup zer...iteup
Return to “Versa Technical Discussions”
