MT conversion
240240
How hard would it be to convert an AT Rb25DET to MT. Also would a RB20DET transmission work on the 25? I found a 25 MT for like 1200
Thanks
Joe
to convert the engine itself is basically easy
you need a flywheel, flywheel bolts, clutch, clutch bolts, pilot bushing (DO NOT FORGET TO SWITCH IT FROM THE AUTO TO MANUAL ONE) and a transmission obviously
the 20 trans works fine, im using it on mine. as it was an automatic engine to begin with.
you also need to ground 1 wire on the ECU or your timing and maps will be very messed up. i dont have the wire but ill look for the info.
240240
that would be great
thanks
