niznos »
https://forums.nicoclub.com/niznos-u14767.html
Fri Jun 25, 2004 1:15 pm
MSD= multiple spark discharge. MSD ignition systems up the spark output and also gives you multiple sparks for 20 degrees of crank rotation.
The bare system is the 6A, it can be had for around $150, and you'll need a 8910 tach./fuel adaptor. The ECU's trouble code 21: Ignition signal missing, will be triggered if you do not use this adaptor or not run at all. It is around $26.
I've ran the 6A for a while now, and I like it a lot. Not an upgrade that gives you big HP's (3-5 max), but is a great compliment to cam/induction upgrades. Cleaner burn, easier starts, better mpg, etc. Not bad for $176.
