WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Tue Mar 09, 2004 3:09 pm
Here's what I did with my knock meter. I installed it while the car was running stock boost, Skyline GTS-t, and adjusted the sensitivity to where it wasn't showing any knock. The I added boost, this way I was sure that any knock that occurred do to the added boost would be immediatly detected.
So for you, just install it while your still NA. Adjust it till it is just barely picking up a slight knock, then add boost.
I tuned for no knock at all, if I got knock I added fuel. In the case of my Kits, I'll be retarding timing and adding fuel.
WD
