msd ignition
bedbull
which msd will work on the ka24de and can adjust the rev limiter:help
JNM240
Car: 90 Coupe, 90 Hatch (CA18DET)
The MSD 6AL will work on your KA24DE and has different plug-in "pills" for different rev limiters. The SOHC needs the tach adaptor since they are 12V, but the DOHC does not, it is 16V. You can use the stock coil if you like, but why not upgrade it to the Blaster coil? If u need how to wire it, let me know.
bedbull
thanks alot .. about how much is the msd system and the cams, i already have the header on , with a sr20 ecu on that is working well
JNM240
http://www.Summitracing.com has the MSD 6AL for $195.95. For your KA24DE, look here http://nismoparts.safeshopper....m?482 for cams off of 95+ from Nismo (i *believe* they work on earlier models).
okisil80
SR20 ECU on a KA? I had no idea that could be done! I'd be interested in learning more about that and if it helps with power output.
SpeedingMonk
Car: drifting, nissans, and keeping all other cars behind me
i dont no but i wouldnt take a computer off a smaller engine (2.0 - sr20) and put in on a biger engine...
letalone its made for a turbo. (the sr20 ecu)
and that it has a worse power curve... but i donno
bedbull
i have working but one problem it is not going over 6000rpm when driving but will go over 7800 when in neutral
SpeedingMonk
well thats y u cant even redline ur car i wouldnt have dont that
