wa-chiss wrote:
The reason you kept "melting" coils is because the MSD 6A/6AL is an ignition amplifier. Yes at under 3000rpm's it's a multiple spars discharge (hence M.S.D.) it suplies the coil with higher voltage at all RPM's. Something any factory coil couldn't deal with. Coupled with an MSD blaster 2 coil, wich has a much faster recharging time, will create a hotter spark. So, you could even get a blaster 2 coil, and still gain power. Especially up in the higher RPM's.
the coils i melted..were not factory or oem replacments..they were cheepo's...accel..ect..there was not a MSD coil in my area at the time to replace it with so i held out till mine arrived with cheepo's for 20 bucks a shot!..
and you just repeated what i said in a different way..what was the point of your post?..to point what out?.you post is confusing to those who dont normally install ingnition systems often..keep it simple ..it works just the same..peace man..and good luck
