Hello! What is the PTU? :? Oh boy, Ok got it Power Transfer Unit... Is that that little black module? I have three of those. I had it running before like i said and the only thing that was coming out of the wiring harness was that black and red cable and green and black. Now down the wires there is a white can of thick cable that was hanging around so i matched it at the other end but is not the same wire they dont match on the inside.
Anyway like i said I get a 12V with switch on from the red and black + Cable and Green and Black - . So when I take the voltage reading it gives me 12V on that specific order so if i switch the cable sequence it will give me a negative reading.
Sorry but how you test if the PTU is driving the coil.?
Anyway I will start troubleshooting tomorrow starting from making sure the Distributor is not wet on the inside and then I'm going to see if there's any spark and then if there's no spark change my ECU I have about 3 as well
