msd btm with blaster coil
sunnys14
Car: S14
i got the BTM wired up on my s14 internal coil, but how would i be able to add a blaster coil to that? instructions would be nice
nissanfanatic
Car: 1992 Nissan 240sx SE
You won't need to.
Edub1
Car: 89 240sx KA-T
Hay Sunnys14, is that a picture of you?
Chezedik
Car: 1991 Nissan 240sx
If you wanted to, you would need a special modified cap. I used to have one when I bought my ignition (from a guy with an S14), but I tossed it. I really don't know if it's worth it unless you are pulling serious boost. And the coil by itself is like masturbatlon. Without the box, you're just jerking off.
sunnys14
Car: S14
i have the MSD BTM (boost timing master) only. i was wondering if i can add a BLASTER coil to my ignition since the BTM itself doesnt have a built in coil
Chezedik
The short answer is yes, but the truth you seek is more complicated than that. (How Yoda was that?!?!)
nissanfanatic
YOU DON'T NEED TO!
The stock internal coil is strong enough to support close to 400ft/lbs of torque, maybe even more, on the KA.
The short answer is it would be stupid to waste time/money on it instead of focusing those funds to something that will benefit your setup.
WDRacing
nissanfanatic wrote:YOU DON'T NEED TO!
Agreed, I boosted 20 psi with before my motor went and the spark was strong the whole time. Proper wires and plugs with proper gap will be all you need.
Glad you got the BTM wired up. I couldn't find the damn wiring info I had. You wouldn't by chance have pics and a writeup for me to add to the sticky would ya??
sunnys14
Car: S14
ill write it up and take pics soon.
all i did really was copy the JWT site on how to wire it... is this the correct way?
