Import_Ant »
https://forums.nicoclub.com/import-ant-u16968.html
Fri Aug 12, 2005 1:53 pm
hey no problem, the only thing you will need is a way to mount the coil, about 8-10 inches of 12 or 10 gauge wire (10 preferrably) a couple of ring terminals and some clamp-type wire taps or soldering iron/solder.
you dont need all of the stuff that comes w/ the 121-8200 set, you cant use the resistor at all and your stock ignition coil plug will work just fine so the 'power tower' isn't needed either.
I'll try and get some pictures up tonight of mine but you'll have to mount the coil, remove your stock one, then rewire the two wires that go to your existing ignition coil to go to the blaster coil.
there are three plugs at your ignition coil. one of the plugs goes to the transistor and it has 3 wires. leave that alone the other is a single ground wire, leave that plugged to the ground. the third is the one I circled in that wiring schematic. it has 2 wires one green and one black w/ red stripe. the green is the ground and the red is the positive. if you have wire taps you can just tap them and run your wires (with the ring terminals) to the appropriate connection on the ignition coil. otherwise you're going to have to cut and solder the wires. right now I'm jsut running the crimp tipe wire taps.
so in short you shouldnt need to buy anything from Jegs else except maybe 121-8213 (mounting bracket).
