MSD Blaster SS
DRFT_HRD
i need to know how to hook up a msd ss blaster coil on a single cam s13 i just want to smooth out my ignition. like which wires i have to clip and run to the postitive and negative on it.
volcomskater773
Car: S14
2 wire plug on the coil. black/red to + and black/green to -.
DRFT_HRD
volcomskater773 wrote:2 wire plug on the coil. black/red to + and black/green to -.
Sweet I suck at wiring so this is really appreciated.
DRFT_HRD
ok so i have another issue now. there is the single wire ground, a plug with three wires and one with two wires the one with two wires one is blue with either a yellow green or white stripe and the other is black and i cant see a stripe i cant tell for sure because it is getting dark.
Modified by DRFT_HRD at 7:10 PM 10/7/2009
volcomskater773
Car: S14
3 wire is the ignitor dont mess with that one.. you ll have to unscrew the ignitor from the mounting plate and put it somewhere. the two wire is the one you want to cut. the black should have a red stripe. if it does thats +.
