MS3x - VG30DE - s12 sev6 project
Discuss topics related to the VG and VE series engines.
wonderingraven
Car: Project: 1987 Fairlady Silvia CA18DET
Project: 1986 Serenity the Daily Driven CA20E
Hi there,
Wanted to check in to see if anyone might have already done an VG30DE with MS3x installed and running maybe there is a write up somewhere that I can't seem to google beyond the DIYAuto solution.
I recently purchased the ms3x 3.5 from DIYAuto I followed their guide as much as I can with the wiring especially to the CAS with the TPS as the pickup on the VREF wire
Basically how it's all layed out here I've followed.
https://www.diyautotune.com/support/tec ... z32-300zx/
I can perform the tests but it's odd as the spark plugs are firing on "coilG - coilL" but if I attempt to crank it wont spark, it doesn't even attempt to fire the coils and I feel like I am missing a step somewhere.
Another question I have has anyone used the VCT I think they are called on the back of the cams with ms3x if so how did you wire it and use it?
Last is does anyone have a base tune for the VG30DE?
Return to “VG30 / VE30 Forum”
