MRev 2vs Plenum spacer
Twizz
Car: 2007 M35X - Stillen exhaust, Injen CAI, dropped on Espelir springs, Morimoto 3K Hid Fogs, Morimoto 6K low beams, Full interior and exterior LEDs, air horn, 35% tint all around(45% on the windshield)
Wassup people,
As the time draws closer to my UpRev and Dyno tune, I wanted to know what else I should put on before I go to the shop ? They told me to add all the things I planned on putting before I go for the tune. So my Question is what is more beneficial to the car (2007 M35X), the Plenum spacer or the MRev2 ? Thought ?
seymore4
Car: 2012 M56
Professional UPREV tuner
plenum spacer.
Twizz
seymore4 wrote:plenum spacer.
Thank you. I just called Motordyne n they told me the same.
built2makeit
Car: 2007 Infiniti M45
will that also fit the 45?
seymore4
Car: 2012 M56
Nope
CPJ LB
Car: 12 G37X Sedan- stealthy modded
14 Altima 2.5
08 Tahoe
06 M35 S (gone)
14 Versa 4dr (gone)
Agreed! Start with the spacer... I immediately noticed the difference prior to my tune then afterwards it went to another level :)
If you're looking to install the Mrev2, I'd look at the used classifieds for them...G35 forums will have them for sale from time to time. I found an Mrev2 for cheap and installed it myself. For me, I noticed the difference in the upper rpms.
Twizz
If you're looking to install the Mrev2, I'd look at the used classifieds for them...G35 forums will have them for sale from time to time. I found an Mrev2 for cheap and installed it myself. For me, I noticed the difference in the upper rpms.[/quote]
Yea. I spoke to someone at Motordyne n he said the same thing. He said that the motor that I have is not the "rev up" so I don't need the mrev. He said the spacer would be more than enough. Because I live in NYC, he suggested I get the Copper Isothermal 5/16".
