Here is what the Fit system looks like.
PapaSmurf2k3 wrote:Canaan- any reason you're thinking supercharger instead of turbo?
Also, at 6-7 psi, I'd look at at least upgrading the fuel pump. Even with an 8:1 FMU, you'd be looking at fuel pressures in the 88-96psi range... which I think the stock fuel pump would struggle to do, if it could do it at all.
Promise Land wrote:sounds like the supercharger kit for the MR18/20 will be out in the Fall. No exact price yet because it hasn't been created. Stock MR18 should go 122 (stock) -> 200hp (+50% hp) easy at 6-7psi of boost. MR20 should go 140 -> ~210hp. Should be OK for manual or auto trans, not sure on CVT.
What do you mean by they have their own oil? Do you use this oil only for the S/C?alperazzoli wrote:Hey there
now this is good timing. I walk into the forum this evening to find a post on the exact same subject about which I have been exchanging emails today with a supercharger shop here in Brazil.
Let me throw in my 2c:
1) I have this thought that a Rotrex style supercharger has a combination of the turbos' and supercharger's disadvantages, namely the lag on the first case, and 'robbing' engine power would be the second case. Why not a roots or lysholm (screw type blower)? I always thought Rotrexes were more suited to big displacement V8 guzzler monsters than to 4 cyl econoboxes. Did I get it right?
2) someone asks why Supercharger instead of turbo. Some good reasons: a- Low revs boost - the S/C can run boost right from idle, whereas the turbo needs some revving up to pick up enough exhaust pressure; b- Cheaper to install and maintain; c- You don't need to tap the oil pan, at least the Roots type and Lysholm type S/C's have their own oil - not sure about Rotrex; d- Less of a hassle, no fiddling with the exhaust manifold/piping; e- It IS different to the myriad of turbos you see around.
I for one would be totally interested in the SC kit. Bring it on!
AFAIK, Roots or Lysholm type S/C's come with their own oil compartment and you really don't need to change it before many many miles (50k? can't remember now).bakerboard wrote:
Yes, I'm 99% sure it could be done, lest the Fit's S/C wouldn't fit (no pun intended) in your engine compartment. Which I reckon it would since the Fit's engine bay is quite cramped, sho it would be a compact unit. But, again, the S/C shown in the pic above (the Fit kit) is a Rotrex. Look my earlier post, you'll see I have my doubts on its efficiency. Could be I just have doubts about it just because I didn't research enough on it. Whereas I've done quite some reading regarding the Roots and the Lysholm.bakerboard wrote: Also, what if we just used the Honda Fit S/C but used our own piping, etc?
Oh, I'm fully aware of the advantages and disadvantages of each, but in my eyes, turbos would be more along the lines of what a Versa owner would be looking for... retaining some of the factory efficiency. Also easily upgradable.alperazzoli wrote:
alperazzoli wrote:AFAIK, Roots or Lysholm type S/C's come with their own oil compartment and you really don't need to change it before many many miles (50k? can't remember now).bakerboard wrote:
That'd be about right. The Supercharger hold its own lubrication oil inside its own oil compartment (analogous to the engine's oil pan). AFAIK some Eaton models only require an oil change every 120,000km, that would be about every 75,000 miles.bakerboard wrote: So, its like a oil pan inside the S/C, that only needs to be changed every 50k miles?
I don't doubt you about the ease of doing it. But some of us would like to get the extra punch while keeping the setup as close to stock as possible. From what I gather, removing the whole SC kit in case you decide to take your ride back to stock to sell it or go through inspection, would be far easier than removing a turbo setup. And, you've got to agree, easy or not to tap your oil pan, it's an extra set of tubing/hosing that could go wrong.PapaSmurf2k3 wrote:Why is everyone so petrified of drilling/tapping the oil pan? That was one of the easier parts to my KA-T build.
That is the goal. Trying to get a kit out there for the Sentra 2.0, Versa 1.8, and the Versa 1.6.bakerboard wrote:Is there a sentra around you, so maybe when you make the S/C kit for the versa, you could also test fitment on the sentra??
Promise Land wrote:That is the goal. Trying to get a kit out there for the Sentra 2.0, Versa 1.8, and the Versa 1.6.bakerboard wrote:Is there a sentra around you, so maybe when you make the S/C kit for the versa, you could also test fitment on the sentra??
Very true... but then again, I wouldn't be supercharging my only vehicle either.alperazzoli wrote: EDIT: Also, I have only one car. If I had another one, probably I'd leave one of them as stock as possible for daily driving, and would go mad performance tuning the other one. Maybe one of the reasons of your peace of mind in doing the KA-T ? hehe
You could lean out your fuel/air mixture, detonate, and throw a rod through your block. You'd need to keep premium fuel in your tank, and possibly upgrade your clutch. Other than that, maintenance would be about the same.bakerboard wrote:Just wondering...
what is the worst possible thing that could happen if you supercharge your DD? and what are the things we need to keep mantained after the kit is installed??
