if this was my car i think i would start by checking out how well your swap was done. there is a very good walkthrough here
zer...ottom you probably want to pay attention to the part where you wire the spedo into the new ecu. it will also give you a great place to check weather or not your getting a speed signal out of your ecu or not, indicating a bad spedo or speed sensor.
good luck
