joe603 »
https://forums.nicoclub.com/joe603-u34652.html
Thu Feb 21, 2008 9:47 am
I don't have concrete numbers, but if you plan on doing lots of highway travel, consider going with a turbo instead of a supercharger. But the supercharger, as long as you don't floor it, will get better MPG than NA. The reason is because at 80mph, you're turning the engine at around 3.5k RPM. That is fast enough for the belt drag effect (for MPG) as lower RPMs would be. With the added pressure from the compressor, it will be more efficient. As Q mentioned, the effect is similar to having the AC on...however, the AC does not make more power for the engine. The clutch concept will make the install much more complex.
JUST REMEMBER....
Getting a proper tune will have the largest impact on your MPG...do it right!
