MPG with bigger wheels
Shift_Altima
Car: 2008 altima coupe 2.5s 6 speed
Does your MPG go down with bigger wheels? I'm going from 16 to 18. Will it decrease/
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
has nothing to do with size.. but WEIGHT is the concern... more weight=less mpgIf you get some 18" rays it will increase the throttle response, if you get stealies it will decrease...
wild willy
Car: 02 Altima SE, 91 MR2, 04 Odyssey
You know....I seem to remember a show I watched that touched on this subject. I believe they said that the larger wheels did slow down the car a bit even though they were lighter...It had someting to do with rotational mass or something.....
Keep in mind, that unless you maintain OEM circm. your ODO will be off as will your mpg
LongBeachCoupe
2005 Lexus RX
I dont see how a lighter wheel can slow a car down, unless you are talking about something as specific as wind resistance against a larger wheel or something...
wild willy
That was what I thought as well......But the show and the car they were testing proved differently on the Dyno
This was a couple yrs ago....
generic808
Car: '08 Infiniti G35 S
'10 Infiniti EX35
All that really matters is the overall wheel/tire diameter. If you go with 18's and run 235/45/18 tires, the total wheel/tire diameter will stay exactly the same, not affecting mileage much at all. You may lose a very minute amount due to rotational mass with wider tires though.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Technically, it is the polar moment of inertia of the wheel that determines its resistance to rolling. For the layman and all practical purposes, the lighter the wheel, the better the gas mileage and suspension handling/tunability.
If you have a larger overall diameter, the speedo will read lower, which means the odometer will read lower which will make you think you're getting worse gas mileage unless you account for the larger circumference(%). My opinion is that you will hardly notice a difference. Even if you do notice a decrease, it will be worth it because you will have a better looking wheel/tire combo.
LongBeachCoupe
2005 Lexus RX
Ahh... now im on 20"s with a 35 profile tire... so what is the multiple of the MPG that the car reads in comparison to the actual? Its like a 2% difference (my car shows X mpg, and i actually get X*1.02 aprox) am i right?
Darius
It all depends on the individual setup for the percentage, but yes you are right in your calculation.
LongBeachCoupe
2005 Lexus RX
yeah... i got a 3.7% overage on a stepup from the 16s to 245/35/20.... so when i get 22mpg its really 22.8 woohoo! now we are cookin!
windhaven
Car: 2008 Nissan Altima Coupe 3.5 CVT Winter Frost/Blond Full Load
No change on my front: Stock 17"'s to 19"'s.
-- Wind
R1Wolf
Car: 2008 Nissan Altima Coupe 3.5SE, Precision Grey, 6-Spd and 2004 Yamaha R1
I haven't seen any change with my 19's running a 245/35-19.
