At a 500 lph rate, without the proper updates to the fuel delivery system that can handle the new flow rate, it will likely leak fuel at the injector seals, line connections, rupture fuel hoses, etc...I do agree that car mileage/age; dirt build-up increases the gas consumption. And the recommended cleaning and maintenace as Nico members say are help ful to keep our 'verts on top_less condition.
Also
TurboChargedSE-R wrote:That's not correct. Yes, a higher-flowing Walbro will mean more fuel flow, but all unused fuel is returned to the gas tank. You could flow 500 lph and it wouldn't make a difference.
As long as your fuel pressure regulator is working properly and can handle the flow...the fuel pump being used is irrelevant.
I still think a high pressure fuel pump will increase your car fuel consumption. Any fuel pump will flow the fuel at its designed value, the fuel then will travel to the injectors which have a fixed flow rate. So the amount of fuel delivered into the combustion chamber is ruled by the injector on-time (injector opens.) The more time the injector is open, the more fuel is consumed. This is ruled by the PCM, depending on several inputs from the engine sensors (i.e. TPS, MAF, O2 sensors, etc.)
Say the injector is open, the fuel delivered will be the fuel flow on the amount of time it remains open. Now IF the fuel flow is increased (by any means, in this case a high pressure/flow fuel pump) and the injector on-time is the same as before, more fuel will go to the combustion chamber. Hence more fuel will be consumed. So the type fuel pump being used is not irrelevant.
All these, without taking into consideration the pressure regulator, which is at the end of the fuel rail, after all the injectors. The fuel pressure regulator task is to maintain the pressure of the fuel on the rail so the correct amount goes to the injectors (when open) and it will be completely closed when there is more load demand (wide open throttle) and will open when there is no load demand. When it opens, the fuel goes to the return line and ends in the fuel tank. The fuel return line is also smaller in diameter than the fuel supply line, which decreases the fuel flow rate back to the tank compared as when it was on the supply section.
Side tracking.... I haven't logged-in a while. Kudos for the great 240sxconvertible.com page. Awesome front pic AZ
Keep up the great posts at NICO - verts
Regards,Luis
