Disabling the knock sensor may be the wrong choice of words. Fooling the knock sensor might be more appropriate. And no the knock sensor does not trigger SES light nor will it even if it fails.93HATCH240 wrote:Wouldn't disabling the knock sensor cause the check engine light to go off? I realize the benefit of disabling it would be better gas mileage but is there any that could go wrong from disabling the knock sensor? Any cons of doing this?rxm6 wrote:1) Disable your knock sensor
Disabling the knock sensor will not give you problems starting the car.edpapaj13 wrote:I'm not sure about the disabling the knock sensor since 'm afraid i'm going to have problems starting the car again. However number 2 and 3 can be done. How much would a Y pipe run install plus part and can this be done anywhere? (pep boys/meinike etc)
Budget is fantastic. They have real quality in their work.NewfoundlandDude wrote:I'm sure that they have more than just Dallas on staff, but I have heard stories of them being slow with shipping & such due to supply.
You could also try Budget Exhaust (LSS Exhaust) out of Toronto, Canada.
It releases HP that the engine already possesses but can't use due to restrictions. Furthermore, a y-pipe with a stock exhaust setup is hardly noticeable.edpapaj13 wrote:...Does Ypipe by itsself really add any HP or is that just to advertise it?
28 mpg.edpapaj13 wrote:...and also anyone with Maxima/I30 with 140K+ what mpg are you guys getting?
Agreed 154867%.Sentientbydesign wrote:Your alignment makes a HUGE difference on your MGPs. Think abou this. If your tires are all going straight, there is very little drag put on the engine, the moment your to or caster change, the car is going to start pulling and dragging your tires.
I'd get the $60 alignment and save yourself money on gas and tires.
