Issac »
https://forums.nicoclub.com/issac-u89863.html
Fri Apr 18, 2008 9:44 pm
Save your money is my opinion. now gas is high and the stuff is really coming bigger and better. There is always stuff like this. Few do much. I don't know what it cost, but even if it did do what they say, how many miles before you would break even?
Also to consider is simply running more air in your tires. Try 38 cold. That works over 28psi and is free.
Also driving slower and steady, and keeping your engine running good.Air filter, mass air, plugs can help even.
But I am not saying you are a sucker, sometimes things do work. I just don't even see exactly what it does, other than claims and claims.
If you mess up your injectors with that special metal whatever inside that thing, or if it messes up your valves or something, then would they cover that? user error?
Sometimes cleaning your fuel systems can help if it needs it. I say snake oil. But like I said, I could easily be wrong.
Acetone in tiny amounts was shown by some to work actually. Might be cleaning effect. 3 oz for 10 gallons I believe. Home Depot or elsewhere.q45 forum did stuff on this.
