kerrton »
https://forums.nicoclub.com/kerrton-u88348.html
Wed Nov 18, 2009 7:56 am
Yeah, more details required. Is the air filter clean, perhaps it's dirty and needs to be replaced? All of the suggestions above are good, none can explain the low mileage on their own, but each contributes a little bit to poor mileage. If you've ruled out all of these obvious things to check, I'd disconnect the battery overnight, which will reset the computer and you can start fresh. The computer learns your habits and tunes the engine and transmission to your driving habits. If you start fresh and drive conservativively (very light on the accelerator and brakes), the car will tune to maximum efficiency. I'd highly recommend trying this if you're exhausted all other options because this is not acceptable.
