Different design in O2 sensors for OBD1 vs OBD2....96 and later are lucky to last 60k....................last as in work as new at high efficiency.
Also oxygenated fuels throw the whole design off and skew the mixture towards excessive richness by 2.7-3.5% as the ecu thinks the excessive oxygen is from a too lean mixture and thus adds more and more and more fuel to try to reduce the oxygen in the exhaust.
The up to 5% lower BTU per gallon of oxygenated means you have to burn 5% more per mile to yield the same power.
A few other blending changes make the whole mess 10% worse also any water in fuel is even more dramatic.
Cold tires are far away from their optimum friction point and cold rear diff fluid is terrible power waster.
Those of you who live where it gets below 40F would benefit in winter from Redline 75w90 rear diff fluid..........probably would pay for itself in one winters fuel cost savings [price of fluid] especially if your cold drive distances are 10 miles as it takes 10-20 miles at speed to warm diff up.Older Q are worse since the fins on diff provide extra cooling.
http://www.drivetrain.com/redlinedifflube.html
