Yeah. I try to warn people about this all the time ... even if the filter feels "dry" to people (minimal oil), it is still going to release some micro-droplets of oil into the air-stream. This oil deposits and burns onto the hot-wire MAF sensor that our cars use, and eventually causes problems. If there is too much oil, it just goes sooner rather than later.svard75 wrote:k&n filter could have released some of the oil into the intake and its collected on the MAF sensor which could in effect cause the same effect as a dirty filter.
I believe it can be carefully cleaned when cold, but I have not done this myself, so please take my words with a grain of salt!USMC5811 wrote:Is it safe for me to clean my MAF? I will get rid of the K&N tonight and go back to a normal filter. Thank you for the input!
Prior to replacing the passenger's side bearing I did spin in and test to make sure it was bad and it was in fact bad. It was also very loud when i would drive next to a jersey barrier on that side with my windows down so i knew it was that side. However, after that i never checked the driver's side so I will definitely do that.The00Dustin wrote:Did you spin the wheel before you replaced the wheel bearing?
Yup I understand that and I check my PSI every day, especially in the winter for that reason. I used to run about 39psi in my tires but right now im running 34. Not sure if that would make that much of a difference but I'm open to all suggestions and i appreciate your feedback!mazz wrote:buddy it could be as simple as air pressure in the <a class="vglnk" title="Link added by VigLink" target="_blank" href="http://www.walmart.com/cp/1077064?povid ... ires_Tires" rel="nofollow"><span>tires</span></a> if you were running 40 and now 30 lb of pressure remember temps drop in November and December my <a class="vglnk" title="Link added by VigLink" target="_blank" href="http://www.walmart.com/cp/1077064?povid ... ires_Tires" rel="nofollow"><span>tires</span></a> lose pressure every year
I know that sometimes my brakes will stick when it is raining and cold out and i can tell because after coming to a complete stop for a short period of time i can hear the pads break free from the rotors when i release the pedal. When i turn hard left from a stop everything is perfectly normal. The noise, which i guess could be considered a groaning type of noise, can only be heard sometimes when turning hard right and accelerating from a stop and it usually happens half way through the turn and lasts about a full second.EdBwoy wrote:If you haven't figured it out yet, I've got a guess for your grinding. Is there a possibility that the brakes on that side are frozen? That could make some noise as you just start to move again.
Out of curiosity, what happens when you turn a hard left from a stop?
It can make a big difference. For long trips you pretty much always want to add a few PSI to your tires to maximize MPG. Dropping from 39 to 34 PSI could accord for as much as 2-3MPG loss.USMC5811 wrote:Yup I understand that and I check my PSI every day, especially in the winter for that reason. I used to run about 39psi in my tires but right now im running 34. Not sure if that would make that much of a difference but I'm open to all suggestions and i appreciate your feedback!
