(Off-topic post, since we did deviate a bit above.)
Setting at the manufacturer's tire pressure is not a bad thing to do, of course, but not necessarily great advice either. While higher pressures will reduce rolling friction, thereby increasing mileage a tiny bit (less of an effect than having too low a pressure), the resulting harsher ride and uneven tire wear may end up being being a good thing.
Comments:
1. People often set their pressures warm (after driving a few miles for example). This is not a good thing, since the recommendation is for truly cold settings. That means you should set the tire to the required value when the car has not yet been driven in the morning - if you have a garage, check it before you pull out into the sun (black tires absorb heat).
2. It is normal for tire pressure to drop 1 or 2 psi over a few weeks to month. If you are not diligent about checking the pressure, starting at mftr recommended 33 or 34psi will make it low after a few weeks. So, imho, it is better to err on the high side rather than on the low side to allow for these periodic drops.
3. Gauges are not always the most accurate - so, again, it is better to err on the high side a bit.
4. Measure and adjust at least once every other week - certainly don't wait for more than a month, and if the weather has changed a lot, then check it sooner.
5. Do get a tread depth gauge - they are
incredibly cheap (the penny and quarter measurement techniques are silly to do frankly!). I have one in the glove compartment in both our cars. Using this to measure the depth at various points
across the width of the tire will give you an indication of how the wear is going.
6. Do get a reasonably accurate pressure gauge. Good digital's and good analog ones are perfectly fine - just avoid the cheapo pencil gauge if you can. Repeatable measurements are necessary to be able to properly adjust pressure up or down ... adjusting for wear.
7. Do get a home pump (electric is easiest) if you can - best to pump the tire up in your garage at home in the mornings when the tire is still cold.
Ideally, the best way to find the right value for you, is to start at the value used for tire load index tests (this value is 36 psi). Then go up or down 1 psi at a time, accurately, over time to find the right compromise between safety concerns (too low), road harshness (too high) and evenness of tire wear
across the tread (with a tread depth gauge). During this period, measure at least once a week and correct the pressure accordingly.
When increasing or lowering the normal set pressure during this period, don't go below the 33 or 34psi recommended by the mftr, or above - for that matter, anywhere near - the max indicated on the sidewall (should be 50 or 51psi for our modern tires). Frankly, if you find yourself setting the normal use pressure
well above 42 or 44psi, then you are probably experiencing a harsh ride and/or not measuring wear properly.
Hope this helps!
Z
