SardarQ »
https://forums.nicoclub.com/sardarq-u31657.html
Tue Jan 23, 2007 1:55 pm
2 questions:
1. I have a rattling sound coming from underneath the car at exactly between 650-800 RPM. I'm guessing its the under body cover?? Its a metal rattling sound. Is there any metallic sheild that is under the car? Only happens in that RPM range. Very annoying. Someone lese must have had this problem - please share!
2. MPG in the winter is very low - not becuase of fuel (oxyginate, etc.); I think this has to do with the EGR temp sensor. Does the EGR temp sensor tell the EGR value to bypass EGR function at low temperatures - this would explain the low MPG. The big question - if this is so - WHY? Why cut off EGR at low temps?
CJ
