Mp3 Headunit
Post all your Nissan electronics, car audio and stereo questions here!
KFL
Car: S14
I'm looking for a mp3 headunit at the moment since my current one stopped working. A few questions I have are -I plan on running a sub 300watts or so is it worth getting a headunit with a sub preouts rcas..-If I just get one with out sub preouts how would I go about running the sub, tap into the rear speakers or could I just use the rear speaker outputs. I might not run rear speakers anyways. But if I do the amp I had had a LPF, I tried it out with the old stereo it worked fine.
Units I'm looking at arePIONEER DEH-P4600MPPioneer Premier DEH-P560MPKenwood KDC-MP425
Rex
Car: None
I may be a bit confused, but it's late.
Get the best featured unit you can.I assume you won't fall for the "plays CDR's" versus "plays MP3's".What type of amp set up are you going to run, if you don't have a dedicated sub amp, the sub pre-outs are pretty much meaningless/useless.If you get one without sub preout's, it should still have RCA's and you should be able to use those for the sub.
I have better experience with the Pioneer units (not the ones you listed specifically), so I say Pioneer.
(I usually ask more questions than I answer :D)
KFL
Car: S14
Well I ordered the Pioneer Premier DEH-P560MP.And wired in my pioneer harness I had lying around just waiting for the stereo to arrive and plug n play.:icesangel Going without a radio for 1week was a tad unbearable especially with a leaky exhaust now replaced though. :D
