tkeskic »
https://forums.nicoclub.com/tkeskic-u33292.html
Sun Jun 25, 2006 8:27 am
You have to use burning software that is able to burn a MP3 audio disc; simply putting the MP3 files on a CD-ROm I dont think works; its beena while since I have done one, but I htink I recall using a MP3 Disc template or something when I did mine;
I just checked the settings, and there was in fact a "MP3 Disc" setting, then you drag the MP3 files into the burning app, and it works fine;
As for it playing in other MP3 players, that puzzels me; Unless you are somehow using a DVD-R, as the Infiniti will not read DVD in the Changer, and the DVD reader doesnt play MP3 discs;
btw; the owners manual has some spcs on the bit rate and stuff that you need to be within for the player to playback the MP3 Disc, this si worth checking if your bit rates are high or low, it will not play
