rjdmmfl1 wrote:
the reason they began making cd players that could read mp3's is because the music quality is higher and sharper in mp3 format vs other formats (wma, etc.) when you burn a disc, part of the process involves converting the mp3 into another, lower grade format. If you have an mp3 player, you can convert that mp3 to like 320 kbps, vs the 160 you get when you burn a normal cd
Another HUGE advantage of MP3 etc is the amount of songs you are able to fit on the disks. You can fit about 130 songs on one cd and you can add folders to organize them as well. You can then scroll through the folders (for instance a different folder for every album on a cd) you create making it easier to navigate all of those songs. I think you can scroll through folders using the scan button on the left of the Bose radio, if not it's the next track on the right. Pretty useful.
Just wanted to add in that you CAN get 100% quality on wma, just depends on your compression level, if you set it to lossless (and you are ripping a normal cd not converting from another format) you can get compressed audio (fit more songs in less space) from the wma that sounds EXACTLY like a cd. Almost all compression has some loss in quality but with most systems and listening preferences your average person won't notice a difference. All pretty moot considering what we're doing here just wanted to point that out.
Also, has anyone had success with WMA's? I tried playing some lossless wmas and they wouldn't play... could be the bitrate I haven't played with WMA's since.
Another note, you don't need itunes, any decent burning program will take mp3's and burn them to a normal music cd. If anyone needs the software send me an email I can get you whatever you want. (I prefer Nero personally)
