morrisliv »
https://forums.nicoclub.com/morrisliv-u245103.html
Mon Dec 08, 2014 9:40 pm
Having a big problem with maxima.
to start with, I was going to replace the timing chain because of a clicking in the front of the engine. I managed to get that finished with the engine in the car, but when I tried to crank it , I couldn't get a injector pulse, so after several weeks of study, I decided that the timing marks had to be off. I pulled the engine and redone all the setup again, making sure the alighnment was correct. I finally finished putting it back together yesterday, but it took a while to get it to crank. but did crank and run , but wouldn't rev fast enough. I ran a scan on it and found that I had left the crank sensor unpluged. I figured that was my problem. I plugged in the sensor but then it wouldn't crank . so I unplugged the sensor and it cranked again. while I had it running I plugged the sensor in again but it stayed running. but it still wont rev. like it should. All i hear is a loud sucking sound from the intake until it finally catches up. then the rpm will run on up. The problem is, that its not showing any codes at all.
