moving to az need to sell stuff, full swap etc
ca18datsun510
Car: bmw 330i zhp, 91 infiniti m30, 89 240sx, 07 zx6r, 05 trx450r
my usb cable is missing so i will put up pics when i get a new cable.
1. low mileage, clean rwd ca18det. has new tomei timing belt, new tensioner, new front and rear main seals, no oil pan gasket, new valve cover gaskets, new t stat. has oem sr flywheel, needs clutch. i have a stock sr clutch, but id put in a new one if possible. brand new s12 starter for sr swap.
no stock harness/ecu etc. comes with complete megasquirt setup for edis 4.has main ecu pigtail, all sensor pigtails, all sensors, most new, new plug wires, coil, pulleys, etc. everything. just needs to be wired up and pluged in.
i also have a volvo intercooler, brand new oem replacement radiator, samco hoses, and a apexi bov on hot pipe i will include.
$1500. i will not ship, nor will i part out, dont ask.
2. rwd ca18de.
i had this setup in my dd 89 coupe, engine ran perfect, never a problem. has new plugs, thermostat etc. also has fresh cut flywheel and oem replacement ka clutch. less then 1k miles on the clutch. also comew with rwd trans.
no harness or ecu.
$500. or i will sell the engine for 400 and the trans for 200. no shipping. no parting aside from engine and trans.
3. ca18det long block.
sludgy. had good compression, but when i pulled the oil pan and valve covers i found a lot of sludge/oil buildup. main bearings etc seem to be good, no play in the big ends of the con rods, cam lobes look good.
300, or 200 for the head 200 for the bottom end. no shipping.
4. i also have the blitz ecu and harness, i took pics for those interested, but i cant load them becuase of the no cable thing.
I WILL TAKE $2000 FOR EVERYTHING, PICKED UP.
driftin8ez
Car: 92 Coupe, Turbo Miata
dude you don't know how bad i want to take a loan out for 2g's right now.
Modified by driftin8ez at 5:06 PM 7/9/2007
