moving the E-Brake handle
mike240sr
Car: 1991 240sx se with sr20det
as a somewhat large person, it is hard for me to use the e-brake during drift events. I was wondering if anyone has moved the ebrake to a different spot. As of right now i made a steel rod that bolts to the factory ebrake hole, and runs to the passenger seat bracket. then the ebrake handle was bolted to the steel rod. I just wanted to see if anyone else have any solutions to my problem
240DRFT
you could use the rhd center console and relocate it to the other side of the shifter.
mike240sr
that is basically what i have done
240DRFT
well it just might be a little cleaner that way
574-240sx
Car: Nissans, Toyotas, Subaru
A decent seat and some decent seat rails will do wonders too. I'm on the tall side and occasionally I use to hit the ebake with my leg, use to give me a good bruise.
mike240sr
I am 6'4" and 230lbs, when i sit as far back as possible in any type of seat my right leg ( mainly knee) sits ontop of the ebrake making it impossible to pull during times when i might need the ebrake
