fortwayne240 »
https://forums.nicoclub.com/fortwayne240-u41562.html
Mon Jun 26, 2006 4:38 pm
Hello. I have made several posts recently relating to the "no spark" issue I was having. I have replaced the Crank angle sensor, which was causing the no spark problem. Up until the point of the CAS failing, the car has run great for the past 2 years.
First off, I was unable to get the car started after I replaced the CAS. I took the valve cover off and lined up the Cams at 10 and 2 to the markings on the crank pulley at TDC. I then installed the CAS according to the FSM. The car finally started.
Second, I proceeded to set the timing to 15 BTDC. I did the fancy FSM procedure for setting the timing, using a brand new timing light. Everything went smoothly. When I went to drive the car, it felt good, right up until I hit 3500 rpms, and well.... damn. My Blow off valve doesn't seem to be quite as loud as it was before, and well... The engine sound like it is going 200 miles an hour when i floor it, and the car decelerates, backfires and shoots out black smoke. when I let off the gas, the car dies.
I have checked the following:
MAF - in working order according the the FSMO2 sensor - good working order according to the FSMReset ECU - seems to be working fine - no codes being thrown.vacuum lines - no problems - no leaks - gauge reads perfect vacuum at idle
I am at a loss to explain the situation. I have entered the timing adjustment mode several times to re-check the timing, and noticed every time that I check the timing with the timing light, it is different !! I set it at 15 BTDC, why wont it stay there? I dont see how the timing can change, I i have not moved the CAS !!
Any help here would be great !!
