Fine. But don't get 17x7 front. Get 17x8 all around with the 215s if you want. However, 225s all around would be better, and wouldn't look as sunken.1990 pignose wrote:OO OK...IM PROB GOING TO GO WITH A 215/45/17 ALL AROUND...WHAT DO U THINK?
Get 225 all around. It is a perfect fit on an 8" wide wheel. It won't rub.1990 pignose wrote:oo ok so when i go to the rim shop i tell them that i want the fno1r 17.8 all around and 225/45/17 all around...1 last ? and u can close this...will the 215 fit better in the front instead of 225? im still stuck on that i will get a little rub when i turn the wheel
I ran that size on the front of my car for awhile, and even at a track event, with my car lowered about 3.5", and at full lock under compression, It did not rub.
You are at stock ride height, so it's gonna be super hard to make anything rub.
On Eibachs?1990 pignose wrote:ya, the car is getting droped 2.1 f and 2.0 rear right after i put rims on
It will handle like crap, and you will blow your shocks quick, even though they are kyb.1990 pignose wrote:but im also getting kyb shocks
