float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Thu Mar 02, 2006 10:34 am
Just as damesta said, you can't install the CAS wrong. The exhaust shaft is keyed so that it will only go in one way. What does happen occasionally is that the key will break off. If that does happen, You're basically SOL. Trial and error or a new cam are the only ways to make it work.
