MOVED: Height issue??...and Shocks + Springs
gunit240
Car: 1990 Nissan 240sx F/B
I noticed this a while ago...my car seems to sit a little bit higher on one side than the other...so I measured from the top of the wheel well to the ground...and the rear driver side sits about 1/4 of an inch higher then the other side...The front was fine. I just had brand new tires and rims put on, so I was wondering if this is a shock/spring problem???...
Also...On the topic of springs/shocks, I plan on buying them pretty soon (for the reason listed above, and for multiple other reasons)...What brands do you guys recommend??...I would also like to drop it down about an 1"-1.5". I'm looking for something affordable...and lastly, how much generally would I pay to get them installed (I would, but I have never touched shocks before..and don't wanna mess anything up.)???...
masticatingcow
Car: 94 Mazda FD3S
I'm moving this to the Suspension guys. You'll get a MUCH more complete answer there.
naed240sx
Car: .....
That height issue shouldn't really be anything to worry about. A 1/4 inch is nothing. A full tank of gas versus an empty tank, or you sitting in the car, would probably change the height by about that much. I really wouldn't be too concerned.
You should do the spring install yourself. All you need is box end wrenches, spring compressor, and ratchet set.
For spring brands, do a search.
