MOVED: Autocross Alignment
All over the world, Nissan products are involved in road racing, track days, time attack and autocross.
240sx AutoXer
Car: 1990 Nissan 240SX SR23DET
Anybody have any recommendations for wheel alignment on a 240sx with 225/45R17 Front245/45R17 RearTOE: Front, RearCamber: Front, RearCaster: Front
Thanks for any help you guys can give me.Joshua240SXSCCA class STX
j-rho
FrontCamber: -4.5 degreesCaster: 6 degreesToe: 1/8" toe out (would set to zero if car sees much street driving)
RearCamber: -2.5 degreesToe: 1/4" toe-in
That's what I ran on my STS car anyway, with 225/45-17 all the way around. I would try running the 235/40-17 tire instead of your current setup - it'll help gearing and CG, and the 235's from Falken or Yokohama are as wide as most 245's.
Good luck!
nismoautoxr
Car: 95 S14
if youre running in stock class like me you can run what I run:
camber-3.5 degrees fronttoe 1/8 " toe out frontI have never seen gain from castor changeRear already has -2degees toe @0-1/16" out .I like to loosen the rear up a little since my S-14 tends to plow abit , so I toe it out a bit for autox.Thats already plenty if your running on the street too.
All you gotta do is two cam bolts from napa to get the front .
Return to “Nissan Road Racing / Auto X Forum”
