Mounts
BuddhistWitch
Car: 85 Saab 900 Turbo
I'm in the market for some new mounts soon. What's so special about Nismo compared to OEM? Some would consider Nismo to be OEM so lets call them stock.
XCrunner19420
Ive heard they are very similar, except that your paying for a name.
rudee023
Car: '03 Infiniti Q45
The rubber used is stiffer than stock. If your mounts are shot you will definately feel a difference. I threw some on when I did my swap and it was like night and day. Very solid feel and hardly any movement from the engine. If you want a little bit more hardcore for a higher price you can go with Kazama mounts. They are polyurethane. Nismo is a very good bang for the buck though. The set of 3 (transmission included) can be had for around $200.
whiterps13
Car: white LE hatch
i know the nismo mounts also make the motor sit a little bit higher, so some strut bars may not clear. i know this has been discussed alot, so if you have a strut bar you might wanna search.
rudee023
Just FYI pilot strut bars work fine if you are thinking about getting the mounts. Check Phase 2.
BuddhistWitch
Well does it matter that I'm going turbo eventually? And is the only difference the stiffness? It could just be the fact that it's a better material, and obviously it will be like night and day because you just went from broken to fixed. You would feel a difference with the stock anyways.
