Ramius83 »
https://forums.nicoclub.com/ramius83-u6643.html
Fri Feb 25, 2005 11:46 am
Ummm, are you missing the actual mounts ON the motor itself, or did you mean that you are missing a "mount kit" to use on your 240? If you are missing the actual mounts from the engine, you are gonna need to purchase a set. If you are needing a mount kit, then you are set on that.
In regards to your question. The differences, other than the steeper price, is the QUALITY of the product and how the company stands behind their products. The McKinney mounts are steep in price, but so far, they are the superior mass-produced mounts. A company or two in the past few months are starting to make them, but until they are widely used, McKinney has the market here. And, as it has happened in the past, if they fail or if you have a problem with them, they will replace them.
Shaft wise, McKinney is the only one to make a driveshaft with the use of their mounts. Unfortunately, if you use the McKinney mounts, your only options are to either have a custom driveshaft shop make you a driveshaft, or just spend a little more and get the McKinney driveshaft. Personally, I bought the RB26 mounts, the RB26 wiring service, AND the RB26 driveshaft ALL from McKinney to use in my S14.
