mounting depth for door speakers in 01-04 pathfinder
dan96max
Car: 96 red max SE 5spd/04 Pathfinder LE Platinum
Anyone know the mounting depth on the front door speakers? Im looking to put in CDT m6 mid drivers in the doors. Mounting dept on them is 2 3/4" just want to make sure they fit before I drop 350 bucks on them. I would think since the bose speakers are pretty big that there should be enough room Thanks
- Dan
pathfinder_se_black
Car: 2000 pathfinder, FG2 civic si
they only way to find out is to take them out and measure but yea those bose speakers come with little amps in the speaker as well.
fueler
Car: 2 Nissan's
2 BMW's
I installed some JBL GTO components in mine, these are the advertised mounting depths:
2-1/16" (53cm) Mid-Woofer, 1" (25mm) Tweeter The component fits and still has some room.... the tweeter I had to bulge out the OEM tweeter grills to get them stuffed in the OEM location.... As far as the speaker, yours are still over a half inch deeper..... you might be cutting it close, but i think it should fit... I hope somebody here has a definite answer for you.... as I really dont know
dan96max
maybe i'll have to bite the bullet and pull a door panel, I just wanna do stuff once. im pretty sure they come with a spacer anyway but then I have to worry about hiting the door panel with them. Let me know if anyone else has any info. Thanks
ganesh21
Car: '12 Honda Pilot
i install the rockford fosgate p162s on the front two door of my 96 pathfinder. i took out the back of the plastic. i believe they will fit.
Midrange Diameter 6.5"Midrange Depth 2.6"Tweeter Diameter .75"
fueler
Car: 2 Nissan's
2 BMW's
I just found your answer, while browsing a car stereo site: Check the speaker dimensions for ANY vehicle: http://www.mobiletoys.com/part....aspx
DUDE you're S.O.L..... Quote »2001 Pathfinder: * Size: 6 1/2" * Depth: 2.25"
Rear Speakers
* Size: 6 1/2" * Depth: 2 1/4"[/quote] Yet my 99 QX4 has 3" depth front and back???? I thought they would have been the same! YES!!!!
ganesh21
don't worry about it. there is a plastic cover that hold the speaker. what i did was cut off the back.
the pathfinder and qx4 are very similar. i not so sure how come they have different dept. maybe it is the enclosure for the speaker.
Modified by ganesh21 at 8:54 AM 9/12/2007
WINNIPEGS_MOST_WANTED
Car: 2003 Nissan Pathfinder
That site says the mounting depth for my speakers is 2 1/4" as well. I installed Alpine Type R's all the way around. They have a 2 1/2" top mount depth and they fit fine.
dan96max
Well I wont have the speakers in time to install this weekend but I think im going to pre wire everything to get it done. If 2.5 will fit then i'll make the 2.75 fit lol even at 2.25 i should be able to make up for it with a half inch spacer with out the speakers hiting the door panel. I havent looked at the door itself at all yet but I think they should be ok if I cut out the plastic speaker "cage" behind them. I'll check that out over the weekend and maybe take my own measurements for future reference. Thanks for the help so far
- Dan
