C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Sun Jun 24, 2007 10:45 am
A BOV's job is to allow the turbo to flow enough air while maintaining some level of pressure so the turbo doesn't see surge. Any location between the TB and the turbo will relieve surge just fine. In many cases BOV mounting may be limited by available space. But my speculation is thast mounting it closer to the turbo has more advantages.
First, in a typical intercooled turbo set-up, there is a pressure drop across the intercooler. So a BOV mounted on the hot pipe will see greater pressure in the pipes (the actual amount will vary with intercooler design), which means for a given BOV opening event (lift and duration) it can flow more air. While the reality is that any properly sized BOV for a given turbo system should not have any problems flowing enough air, being able to flow more air on the onset of a pressure spike can reduce the peak pressure seen at the spike. If you mount it close to the throttle body, if there is a high pressure spike, the BOV needs to remove the excess pressure from right at the compressor exit moving air all the way through the rest of the plumbing. The response of the BOV where it matters most (at the compressor) is a little higher.
Second, A hot pipe mounted BOV will reduce some of the heat load placed on the intercooler. Intercoolers aren't typically able to exhcange heat at a constat rate with the ambient air. Instead, intercoolers are typically designed with some extra mass in it's walls so that it can store heat from the charge air even if it can't exhange heat as quickly with the ambient. Typical driving, even on race tracks have many occassions(braking and most turns) where you are not introducing more heat to the I/C, but the movement of the car is still allowing the I/C to transfer heat to ambient air. This could result in small improvements in the long run for performance, as I/C's will absorb more heat when they are cooler. This effect is particularly true with vented BOV's.
But as I stated already, any location will suffice for all intended purposes. The differences will be small and negligible. I wouldn't stress yourself too much with these details as in many cases, finding a place to mount it can be enough work already.
