Dan1200sss »
https://forums.nicoclub.com/dan1200sss-u166632.html
Sun Jul 03, 2011 2:22 am
Just changed my oil from semi syn to full syn motul 15w-50. My ca18det is freshly forged and balanced (Cps,spool rods, acl race bearings etc.) and running a Greddy T518z. So wanted a nice top quality oil.used elf run in oil for 800kms then went to castrol semi 10w-40. Was told 15w-50 or 10w-40 full syn would be good next so i grabbed the 15w-50 motul the other day as it was in stock at BNT. Seems to run good as on it...Has higher oil pressure than the old semi 10w-40 tho. Like 10psi more at idle (now at 40psi at 1300rpm instead of 30psi) What are you guys thoughts
