joe603 »
https://forums.nicoclub.com/joe603-u34652.html
Thu Nov 01, 2007 6:41 am
RTV is not needed for the spacer install. If you decide to use it, be careful not to overdo it. Excess gunk could go into the intake track and cause problems. The Spacer is basically a thick gasket to separate the upper and lower plenums.
The coolant bypass helps keep the TB cooler, but you need to engage it during colder weather. It's a quick and easy mod.
