Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Mon May 23, 2005 1:19 pm
sounds like ignition timing. Especially the backfiring.
I had a similar issue happen when I replaced the timing chain. I put it all back together properly, but the CAS was 180 degrees out, even though I had installed it by the book. I pulled the CAS, turned it around 180 degrees and shoved it back in. Car started up.
This does, however, require you to pull the CAS about a hundred times. You need to search for the sweet spot that allows you to rotate it properly when setting timing. Otherwise, you'll encounter one of the mounting bolts and can't go any further when trying to get it back into timing. I found it easiest to leave the valve cover off for this operation. You won't squirt oil all over the place, so you'll be fine.
