DanielIser »
https://forums.nicoclub.com/danieliser-u13807.html
Sun Jul 10, 2005 8:12 am
Ok. I get spark on all but one of the coil packs and i have even switched that to a different plug to see if it was just that plug or the pack itself. The pack seems to be bad but that shouldnt stop it from starting. I pulled the fuel rail yesterday and none of the injectors are leaking or getting stuck open. As for the timing it was 180 degrees off before and i had to redo it. As for now though i had the motor set TDC , then aligned the cam gears then ligned up the marks on the cas by the book. I tried getting a code off the ecu but it just gave me the all clear (55). Im gonna pull it and put it back in to make sure there are no lose connections but im stumped at this point. BTW there is compression, not sure as to exact numbers but i had the coilpacks in with no spark plugs and not bolted in and turned it over to check the fule injectors and all 4 packs shot out in sequence. Thanks guys for the help
