jamesblonde82 wrote:you need to remove the top and lower chain guards. what engine do you have?
zer...d.htm
check that out i think it will be of help. i bought my 92' vert with the same noise, and nissan recommends that the upper and lower guards not be replaced, but removed completely. also you need to make sure your tensioner is working properly. its all explained in that link. good luck.
this is true for the KA24DE engines of 1991+ vintages... so Garret, don't bother w/ this one...
Quote »might be a sticking valve its common on old engines or might need a valve adjustment[/quote]also, this is true for the later engines as stated... our SOHC KA24E engines came w/ hydraulic valves, not the fixed/shimmed valves. but they can "stick" as well d/t clogged dirty oil up thurr
check oil level as stated or change to syn to mebbe help clean out those oil passegeways, mebbe try seafoam, there's also a check on the hydraulic valve s floating around via FSM specs...
