Motor symptoms (search has been done) Help if possible.
undead310
Here are the facts- -both lights =brake light and check engine light= stay on until rev'ed over 3k then they turn off. But once the rev drops the lights come back on.-Motor turns and idles fine until gas petal is pressed on.-Once gas petal is pressed car begins to move but jumps (stalls and goes) constantly and dies if gas is not smashed on and held over 3k to 3.5k rpms But Eventually dies anyway with in a few minutes if it isnt in constant motion above 3k rpms.-In order for me to move the car I have to keep it up on the rpms and shift =(- Engine has been sea foamed and checked for leaks and none can be found.
-There is also the ticking coming from the back of the drivers side fuse box,which is hell trying to pinpoint where its from.
Thats the issue, the search function has been used but I was curious if anyone has had the "exact" same issue with a KA24DE motor. Thanks in advance
