marty1mc »
https://forums.nicoclub.com/marty1mc-u151866.html
Thu Dec 30, 2010 1:45 pm
I think the motor will bolt up, but the harness and ECU may be an issue. You will have to research where the alternator harness ties into it and the ECU mounting, harness routing. Check out HybridZ.org to see if anyone has done it. They may even be able to help you through it as well.
But, BTD is right. You can pick up another NA motor pretty cheap. I sold mine that ran great for a couple of hundred dollars. I just wanted the thing gone.
