jdm_master_X »
https://forums.nicoclub.com/jdm-master-x-u30964.html
Mon Mar 27, 2006 7:43 am
while the motor is out, if u have spare money, u can slap a few parts on it, clean it up while you can (especially if u have a parts washer, u can clean it internally). just make sure after cleaning u spray WD on it so the parts do not inhibit any rust. and make sure to measure the parts thoroughly and accurately before throwing them back on. and of course, dont be cheap with the lube. ive used vasoline on so parts because vasoline metabolizes with the oil when it heats up. its a nice trick. haha.
well good luck on the swap. and if u are interested, i have rebuild specs if u need them. ill send them to you. take it easy man.
