Desert Rat »
https://forums.nicoclub.com/desert-rat-u54558.html
Tue Feb 05, 2008 5:55 am
This swap has been surfaced on about every Nissan board out there.
I've seen it done once. It was the Project X that the Nissan guys put together at the Phoenix proving grounds. It essentially had a QX4 drivetrain with the VQ motor.
The VQ motor is wider than the VG, which is why the VQ was never offered in the D22 chassis - because it wouldn't slide down between the frame rails in a frontal crash. To get a VQ engine in a D22, you'll need to have custom headers built, as well as custom motor mounts. You'll need to take the transmission from the donor truck as well. I think you can still use the D22 transfer case though, as they all use the TX10-A case (if you get a 4x4).
What you'd need is a complete donor vehicle, as the wiring harness, computer, transmission, and engine all need to be swapped in to make this work. If you have smog tests, you'll need to ensure the OBDII ports are all intact, and all your sensors, etc. are enabled.
I know the guy who did the swap for Nissan. He's a good old friend of mine and I'll tell you - he'd have no interest in doing another one.
